04-18-2017 09:10 AM
04-18-2017 09:49 AM
It is not possible in IMAQdx on Windows with a DirectShow/UVC camera. The way IMAQdx interfaces with DirectShow has the OS translate the images into Mono8 or RGB32 before IMAQdx gets the data.
If you plugged it into a NI Linux RT embededded system (like http://sine.ni.com/nips/cds/view/p/lang/en/nid/212667), you will get YUY2 raw data, because the conversion to RGB32 takes place in IMAQdx rather than the OS.
Eric
04-19-2017 12:39 AM - edited 04-19-2017 12:40 AM
I think with some change in camera setting parameter with max you could get image that is almost is raw
Esp camera Bayer change
but I am not sure about it
