10-14-2015 11:24 PM
whenever i try to run the program for inspectioning the image acquired by VBAI i am only destined to get an error as inn the below image. Sometimes i prompt to the message that "the session you are using is no longer valid". What to do to take away these errors from vi? The relevant error code is -354713.
10-14-2015 11:31 PM
10-14-2015 11:44 PM
Thank you. Hope this wil be my solution.:)
