05-25-2016 04:31 PM
Using LV2010, gone back to a PC that's been unused for a while to access some old vision programs. On the block diagram the IMAQDX property node is disconnected and while loading the file I get a message that says, "missing resource file imaqdx.rc"
Suggestions?
05-26-2016 12:59 AM
05-26-2016 07:39 AM
Snip attched.
05-26-2016 09:06 AM
Please try the following:
1. Go to control panel » add remove programs » National Instruments software (double click this), and "remove/delete" the following items:
NI IMAQ
NI IMAQ runtime
NI IMAQdx
NI IMAQdx runtime
NI IMAQ IO
NI IMAQ IO runtime
(and any other item related to "IMAQ")
2. Reboot the PC
3. Install this:
NI Vision Acquisition Software February 2014
http://www.ni.com/download/ni-vision-acquisition-software-february-2014/4584/en/
4. Reboot the PC
5. Verify that the problem has been resolved.
Daniel C.
05-26-2016 09:56 AM
05-26-2016 10:06 AM
Hello Hatef.fouladi,
That is a kind offer but I am pretty sure the problem is with my IMAQ. I am going to unistall and re-install. I will let you know how that works out!
Thank you.
06-02-2016 07:56 AM
For anyone following this discussion, I did resolve the error message, but only by completely removing everything NI-related and then reinstalling. A major PITA!.
