From the example image it looks like you might be able to detect some cracks by applying a high pass filter across the nearly uniform regions.
Altermatively, if most cracks appear much darker than the background, as is the case for this image, then you could also apply a dark blob location tool that looks for very elongated blobs...
Good luck!
