Machine Vision
detect cracks in solar cells
How can I use Dark IV measurment to detect a cracks inn the solar panels
@9949633612 wrote:
hello,
    Iam using vision assistant 8.5,labview 8.6,my requirement is to find the cracks in solar cell,can any one suggest me a solution,iam sending the sample image
Message 11 of 12
(757 Views)
From the example image it looks like you might be able to detect some cracks by applying a high pass filter across the nearly uniform regions.
Altermatively, if most cracks appear much darker than the background, as is the case for this image, then you could also apply a dark blob location tool that looks for very elongated blobs...
Good luck!
Message 12 of 12
(712 Views)
