09-05-2014 03:55 PM
the event you call "mouse up" is not a button event, but an image event!
So, click on this event, select "edit events handled by this case" -> select "Image" -> select "mouse up". You can get rid of the button "mouse up".
Also, your stop button does not work for me, since the matching loops continuously and seems to override all other events.
Tell how it goes.
K
09-05-2014 05:02 PM - edited 09-05-2014 05:23 PM
actually i think that when i enter into the button event" mouse up" i can mouse click two point . However if i change the top level button event to image event, i can not click twice because if i change the top level while loop(loop twice) all the top level event while change accordingly.
I use the highlight execution and find that when i enter into the button event "mouse up " the vi isn't let me to mouse click two points.so any suggestions that i can click twice and get the two points coordinates? by the way is that right to get the two coordinates from the shift register (the way i use)?
for the stop button i also do not know why i can not stop in the match event ?
09-06-2014 03:01 AM - edited 09-06-2014 03:02 AM
I am attaching slightly corrected "Main.vi". If you select the "rectangle ROI" tool, you can learn the template, if you select the "point ROI" tool, you can select the coordinates. (I cannot attach a .vi file so i changed it to .txt - just change the extension back to .vi).
I do not understand why your entire program is event driven. It's a bit strange, especially the matching part... But anyway, for matching, you could use a timeout event, insted of indefinitely waiting for a button event. I suspect that's why you cannot stop the program after performing the matching.
K
09-06-2014 09:19 PM
many thanks for your kindly help
