Machine Vision
coordinate transform--robot
Hatef.fouladi 已写:
sppose you have two point  with distance of 1 cm
you  find out that this two point distance is 3 pixcel in image
so if you check bellow image you have this
x step 1
y stem 0,98
unit :cm
hello sir:
  thank you, i understand "x step" and "Y step".
Message 21 of 34
(1,957 Views)
now i know the transformation from pixel to real world unit. but i had encounter new problem in this application. how to make transformation from image coordinate to robotic coordinate? is anyone have experience on it? thank you very much~~~~
Message 22 of 34
(1,806 Views)
for this the easy way is that
after calibration regard 4 point in four corner of your image and also one point in center of image and steer your robot one step in y and one step in x in that points and calculate displacement of your robot in x and y axes in this case you will know what is relation between your robot moving step in x and y and and area of the environment that each pixel cover from outside
for example if you move robot one step but you find that this movement is two pixel in image so you can not order you robot to move same as one
Message 23 of 34
(1,799 Views)
Hatef.fouladi 已写:
hello master: would you like to give me a reference or example? i had check the internet and got some information. i knew the key point is the transformation between vision coordinate and robot coordinate. the key point is transformation.. thank you very much in advance.~
Message 24 of 34
(1,791 Views)
but as trick I always use for such project
after calibration I found ratio of robot step vs pixel step and then re sample image size to reach 1 ratio between robot and pixel
in this case for any pixel size you can steer your robot easly
Message 26 of 34
(1,782 Views)
Hatef.fouladi 已写:
hello master:
  ratio=robot step VS pixel step  ? or
  ratio=robto step VS realworld step?
Message 27 of 34
(1,774 Views)
ratio here is means robot step VS pixel step
but because in calibration you found ratio between image pixel and realworld
so at the end you will be have  robot step vs real world
based on image processing
I hope I could explain it well enough to understand
Message 28 of 34
(1,772 Views)
Message 29 of 34
(1,772 Views)
Hatef.fouladi 已写:
hello master: i get the image coordinate and robot coordinate. and calculate the ratio between .i seem that hard to get the relationship between them. would you like to give me any suggestion?
Message 30 of 34
(1,748 Views)
