NI Home
Cart Cart | Help
You are here:
Reply
Member Gyc
Member
Gyc
combine/join images
Hi. I want to acquire images from inside a tube. The tube spins and moves so that the camera goes inside and takes pictures in a spiral movement. I have the position of the tube (angle, linear position). How can I recompose the pictures into a larger picture of the tube internal surface, with X coordinate from 0..360 and Y coordinate from 0..Ymax? Any suggestions appreciated. thanks
Active Participant
Silver_Shaper
Re: combine/join images
[ Edited ]
Hi Gyc..
Do you want to do Mosaic Image. If so this can be done by converting your pixels intensities in 2D Array (IMAQ Image to Array) and perform the array manipulation (Not applicable for RGB image).
Sasi.
Certified LabVIEW Associate Developer
If you can DREAM it, You can DO it - Walt Disney
Trusted Enthusiast
BruceAmmons
The quick and dirty method is to create a new image and set the size to the full image (0..360, 0..Ymax).  I would also fill it with a solid color, either black or white.  For each image you capture, figure out the upper left corner and use Image to Image to paste it into the large image.  You will need to figure out how to do the wrapping going from 360 to 0.  Once you are done, you should have a collage that includes all your images.
The problem with this method is the overlapping edges and the distortion.  The pixels at the edges will not match up exactly due to distortion and perspective.  The ideal solution would be to gradually fade from one image to the other so there is no edge.  Also stretching and adjusting images to fix the distortion and perspective issues.  It really depends how accurate you need the final image to be.
Bruce
Bruce Ammons
Ammons Engineering
Member Gyc
Member
Gyc
[ Edited ]
Thanks, Bruce, for the suggestions.
I hoped that, by now, there would be some "tools" to do what I need.
Where and how is camera calibration data stored?
I'll have position data (corresponding to piexl (0,0)), and I'll have to figure out where in "big picture" it will land.
I gues I'll have a bit of coding to do.
Member Gyc
Member
Gyc
Thanks, precisely what Bruce also suggested.
I'll be using good old b/w images, no color. :smileyhappy:
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
