Machine Vision
Reply
colour to grey scale and crack detection
Go to Solution
how to convert a colour image to grey scale. also i want to know how to detect the cracks in the objects from their images
Message 1 of 15 (2,329 Views)
Reply
Accepted by topic author saillesh
‎08-27-2015 06:09 PM
Re: colour to grey scale and crack detection
There are 3 planes involved in a color image. Each plane having values 0-255. By extracting any single plane you can convert the image to a grey scale one.
Try extracting the luminance plane (in color plane extraction).
Use vision assistant initially to get an idea.....
Message 2 of 15 (2,317 Views)
If the crack in really nicely different from the object then applying a proper threshold and removing small particles and going with a particle analysis will be enough.
But we need details.If you can post some images then I can suggest you a method
Message 3 of 15 (2,317 Views)
Use the vision assistant to start with ,as it will help you extract the colour planes and (also gives an option to convert your image to a grey image) as well as it will help you learn about other vision utilities which labVIEW offers . You can detect the cracks or edges by setting proper thresholds . Please describe your application in a little detail so that I can help you with a more precise solution.
Message 4 of 15 (2,311 Views)
Reply
Saillesh,
What muks suggested is a very practical approach. I personally implemented it with object filtering to detect cracks in an online ceramic plates inspection.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
Message 5 of 15 (2,309 Views)
[ Edited ]
to convert a color image to gray scale you can average all three planes or you use different weights for the color planes. Typical weights are
30% red + 59% green + 11% blue
See also http://forums.ni.com/ni/board/message?board.id=170&message.id=422864#M422864
Message Edited by Jörn on 2009-08-12 12.08.2009 11:48 PM
Message 6 of 15 (2,296 Views)
i wan to detect the cracks in tracks of train .can i use fft for this . if any other soluion please help me
Message 7 of 15 (2,235 Views)
Reply
i have to inspect cracks in the train  tracks . is your method of object filtering is suitable for that ?.
Message 8 of 15 (2,234 Views)
Reply
Well posting a few sample images will do a lot of help. I mean there is no other way  we can suggest algorithms to use. We can only keep guessing.
Message 9 of 15 (2,232 Views)
Reply
im posting my pictures here  (with and without cracks),could u help me with the algorithms.i have taken fft for this, is there any option to get the strength of fft to compare the images?
Message 10 of 15 (2,174 Views)
Reply
