04-14-2016 04:24 PM
I have a NI PCIe-1433 frame grabber, I want to use it with a Photonfocus MV1-2080-160-CL-12 camera. To set the camera up in NI MAX, it requires the so called 'camera file' (.icd file). Unfortunatelly, the camera file I found in NI's website is borken.
http://sine.ni.com/apps/utf8/nipc.product?asid=1102&pid=11422
If anyone has a working camera file for this camera?
Thanks for helping.
04-22-2016 10:33 AM
As to what I see is that the link you provided leads to a location from where you cannot download the camera file. Something is wrong, but I see no chance to download a broken file from there.
04-25-2016 10:30 AM
Yes, some of the default camera files have bugs, one thing that surprises me with the one you mention is that line 5 is :
InterfaceInfo (1430) {
When I would expect to have :
InterfaceInfo (1433) {
Because here, it says that the supported hardware is 1433 and 1435. So just try to correct this and see what happens.
Epictetus
04-25-2016 10:32 AM - edited 04-25-2016 10:34 AM
camera files can be downloaded from NI's public ftp : ftp://ftp.ni.com/support/imaq/camera_support/camera_files/digital/
but before you get a camera, it is often good to check with NI camera advisor to see if the icd file exists.
if it doesn't, then you'll have to build it yourself with the cam file gen that you can get from here : ftp://ftp.ni.com/support/imaq/pc/ni-imaq/cfgenerator/3.0.1/
Epictetus
05-02-2016 04:04 PM
I wrote an email to Photonfocus and followd their instructions and it worked. Here is their reply:
"Please download the "NI Camerafile Generator" from the NI website. You can find the *.icd file in our PFRemote\fg_files folder. Please open the icd and change the parameters:
Width 2080
Height 2080
PixelFormat CameraLink 2Tap with 80MHz Pixel clock"
05-03-2016 12:39 AM
Glad you found a solution, having to edit ICD files is always a bit risky.
Epictetus
