02-19-2015 09:11 AM
I have an 8-bit grayscale image which is obtained after subtracting 2 images. I have attached the image to the post. there are 4 white regions in the image.
I am basically interested in
Solved! Go to Solution.
02-21-2015 12:20 AM
Hi
I have replied to the problem in your previous post here
http://forums.ni.com/t5/Machine-Vision/create-an-image-of-dimension-3969-X-260/td-p/3090967
Did this solve the problem?
Regards
Aveo
02-21-2015 06:16 AM
Hi Aveo,
Thanks for your reply, it works all fine now.
