10-14-2014 04:28 AM
10-24-2014 07:26 AM
Hello BlueCheese,
Apologies for the late responce, for some reason i did not get an notification any more or i missed it. Anyways i tryed using the "get image data" and i got the same error in the same cases again, i have always gotten it at the configure aquisition. this time i repoduced the error by having the lens cap on it. When ever its on it will give me the error on start up. if i remove the cap and retry it works.
Jeroen
10-24-2014 10:51 AM
Can you put a breakpoint after the configure succeeds, then put the lens cap on, and get the array contents from that point?
10-27-2014 04:35 AM
Hey there,
I made the attached vi and ran it. What i did notice strait away was that the size of the aray decreses by alot after i put the cap on. is this the info you meant? the arrays ar roughtly 30.000 point to 55.000
Jeroen
10-27-2014 10:49 AM
@JeroenP wrote:
Hey there,
Jeroen
Hi Jeroen,
The decreased size makes sense because the data is JPEG-encoded and thus the size is typically proportional to the image complexity. Needless to say, a black image (such as when the lens cap is on) compresses very well.
Would you do me a favor and add a "Write To Binary File" in your VI and re-post these files as JPG files (just save the binary content under a JPG extension)? Your attached file as ASCII arrays would take me a bit of effort to convert back to binary manually.
Eric
10-28-2014 03:56 AM
Hey there,
used the same program with a write to binary file, when prompted i saved them with .jpg as addtion. Im not sure that makes the files jpeg tho, for extra measure i attatced a vi which converts the string data to 1d array again, might need to type cast it but its the raw data.
Jeroen
10-28-2014 03:56 AM
Ps it is saved in LabVIEW 2014 let me know if you need it in a different version
10-28-2014 05:14 AM
Hello JeroenP,
I cannot open the VI (still stuck on 2013 SP1 on this pc).
However, the saved file does not seem to be a JPEG.
Can you use a VI like "IMAQ Write File 2" to save to JPEG?
10-28-2014 05:26 AM
Hey,
That was what i already suspected. here is the raw data in 2013 LabVIEW, i can use the VI to save if you still need it after this.
Jeroen
