06-29-2016 09:41 AM
Hi, I have a video in avi form which I would like to segment by each frame and save the image as a tiff. Ive done this in a while loop but it doesn't work. anyone know why?
thanks
06-29-2016 11:53 AM
Hi Stephen,
For file path input, please give complete path including file name for each file.
-Currently directly you are giving application directory as path, to that append the following
-Since you need each image to be saved first get the iteration number and convert to decimal string and concatenate it with .tiff
-Use the resulting string as input to Build Path and base path from application directory.
-Pass the appended path to IMAQ Write File2 VI.
Let me know if it works.
06-29-2016 12:00 PM
