Machine Vision
Why MAX5.0 not report right XML file settings from AVT GigE camera?
Well, I was a little busy and haven't contacted them yet. So no, it's not resolved. Have you tried the work around? It just can't be done inside MAX if that option isn't there.
Message 11 of 14
(793 Views)
Hi, by work around do you mean to write register 14104 (RegExposureMode) with "external (enum)" ?
I have not tried this yet as I am not familiar with writing directly to the register. Will explore this option and update any new findings here.
Message 12 of 14
(786 Views)
I've gotten some information from AVT with regard to this issue.
Due to GenICam's naming convention, the ExposureMode in GigeViewer is equivalent to the ExposureAuto in MAX.
So for External triggering option, select Others under ExposureAuto in MAX.
Works fine for me. Let me know if this works for you.
Message 13 of 14
(754 Views)
Thank you for share. That's good to know. :smileyhappy I'll try it once I got a hand on it again.
Message 14 of 14
(740 Views)
