05-07-2012 03:38 PM
I have a AVT Prosilica GC660M GigE camera. It had a touble to synchonize with an external trigger. My ex-colleague posted this long time ago (http://forums.ni.com/t5/Machine-Vision/Problem-wit
Lei
05-08-2012 05:01 PM
Hi Lei,
I am not exactly sure why you are not seeing all the attributes, but it could be a few different things causing it. First let’s just make sure you have all you attributes being displayed (follow instructions from link below). What happens if you delete the XML file then set your camera to “External” in the GigEViewer software, then load MAX? Do you see any changes? Can you post a screenshot showing the camera attributes from MAX. If you have your camera set to External from GigEViewer and you try to grab from the camera in MAX do you get a timeout error, does it trigger external, what happens?
Why Can I Not See All of My IMAQdx Camera's Attributes in Measurement & Automation Explorer
http://digital.ni.com/public.nsf/allkb/9FA7FEE4FC5
Why Won't My Allied Vision Technology Camera Work With National Instruments Software?
http://digital.ni.com/public.nsf/allkb/470DA6BDE38
Tim O
05-14-2012 11:54 AM
Hi Tim O,
I deleted .xml, .iid and .icd; set the cam to external in GigEViewr, then loaded MAX. Same thing, only "timed" option showed.
I don't have the external setup right now, I'll get back to you later. But I believe I tried what you said before, and MAX works with the external trigger even under the timed option. My inital thougt was to go ahead and edit xml file, but since I don't realy know anything about xml, that failed.
Here's the screenshot, thank you,
Lei
Lei
05-14-2012 01:17 PM
Did you close and reopen MAX after updating the XML file? Also, what version of Vision Acquisition and/or IMAQdx are you using?
Eric
05-15-2012 10:39 AM
Hi Eric,
Yes, I did. It's the same. I have Vision Acquisition Software - August 2011 and NI-IMAQdx 3.8.1.
Lei
05-15-2012 11:06 AM
Can you attach your camera's XML file to this discussion?
Eric
05-15-2012 11:15 AM
Sure, and the work-around is to write register 14104 (RegExposureMode) with "external (enum)".
thanks,
Lei
05-15-2012 11:24 AM
This looks like the feature is simply not implemented in their XML file:
<Enumeration Name="ExposureMode" NameSpace="Standard"> <Extension> <PvDelete/> </Extension> <Description>Method of control for exposure duration. Timed mode: exposure duration is set by ExposureTimeAbs.</Description> <EnumEntry Name="Timed" NameSpace="Standard"> <Value>1</Value> </EnumEntry> <Value>1</Value> </Enumeration>
Things to note are that there are no additional modes listed for ExposureMode besides timed and it doesn't actually redirect to a register (it has a "Value" entry rather than a "pValue" that points to a register).
It does appear that the "ExposureAuto" feature does actually redirect to that same register you are setting manually (setting it to "other" writes a 0x4 to 0x14104).
I guess this feature is working in AVT's software because their viewer does not actually use the XML file through GenICam like third-party software does.
Eric
Eric
05-15-2012 01:24 PM
Thank you Eric. I'll contact them for what you observered. Hope they can fix it.
Lei
09-11-2012 08:34 PM
Hi Ishi, did you get the problem resolved? I am facing the same problem right now with an AVT GT 1910.
I need to change the ExposureMode to "External" but am unable to do so in MAX.
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
