07-12-2017 09:59 PM
Hello,All
Both VI "IMAQ Find Circular Edge.vi" and "IMAQ Detect Circles.vi" can detect circular, both can get the coordinate of circular's center and the radius,but I 'm not clear about the differences,the respective advantages and the disadvantages.In which case I use "IMAQ Detect Circles.vi" is better?and vice versa.Thanks!
Solved! Go to Solution.
07-13-2017 08:36 PM
Does anyone clear?I am looking forward to hearing from you soon.Thanks!
07-17-2017 06:02 AM - edited 07-17-2017 06:04 AM
Below are my inferences:
IMAQ Find Circular Edge.vi and IMAQ Detect Circles.vi can be used to detect circle. The main difference between them is how they get the edge points and do a circle fit:
IMAQ Find Circular Edge.vi: Internally uses Spoke which uses annular ROI and along the search lines specified identifies edge points and then does Circle fit on the points obtained.(Ref: http://zone.ni.com/reference/en-XX/help/370281AD-01/nivisionconcepts/edge_detection_concepts/)
IMAQ Detect Circles.vi: Uses Curve extraction and contour analysis algorithm to identify the curves and detect the circle (Ref: http://zone.ni.com/reference/en-XX/help/370281AD-01/nivisionconcepts/contour_analysis_concepts/)
-Apart from above one more difference is type of images on which algorithm can be used: IMAQ Detect Circles.vi works only on U8 images whereas IMAQ Find Circular Edge.vi works on below types (Ref: http://zone.ni.com/reference/en-XX/help/370281U-01/imaqvision/imaq_find_circular_edge_3/)
07-17-2017 07:26 PM
