08-08-2012 03:45 AM
Just a quick question, does "image control display" come with labview/vision assistant evaluation? In the vision utilities palette I can not find it. I am looking to display the image on the block diagram.
Damien
Solved! Go to Solution.
08-08-2012 07:57 AM
This control coming with either Vision Acquisition Software or with Vision Development Module.
This is display for Front Panel. You can't display image on the Block Diagram.
08-08-2012 08:27 AM
I have activated the vision development module, so do i use the vision acquisition vi under vision express. Yes I am looking to display it on the front panel,
Damien
08-10-2012 08:17 AM
Hi Damien,
Thanks for your post. Please see this article that explains more about the Image display control: http://digital.ni.com/public.nsf/allkb/1A0508DA3EA
You will need Vision Acquisition Software, also referred to as NI-IMAQ in order to see this control on your front panel. Here is a link to where you can download this from: http://joule.ni.com/nidu/cds/view/p/id/2975/lang/e
Hope this helps.
Kind regards,
08-12-2012 11:25 PM
You do not need to install Vision Acquisition to get the Image Display control (though that is one way to get it). It is also installed by Vision Development Module.
I suspect the issue is that you are looking at the palette on the block diagram, when really you need to look at the palette for the front panel (as it is the same as any other control/indicator).
Eric
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
