05-07-2008 03:55 AM
05-07-2008 03:49 PM - edited 05-07-2008 03:50 PM
05-08-2008 03:59 AM
05-09-2008 06:06 AM
I have done something similar to align and focus a laser. The VI looks at the x-y co-ordinates and also measures the radius and roundness of the spot. You may have difficulty finding an object if your lighting isn't correct. You should select a plain background to maximise the object you are trying to detect.
For information we use a Watec 902-B analogue CCIR camera and a PCI-1409 IMAQ card. You will need Vision development software (at least version 7) as well as Labview. You will also need IMAQ software and you may need other software if your camera is FireWire or USB.
The VI was writen in version 7.1.
I hope it points you in the right direction.
Dan
05-09-2008 06:41 AM
05-12-2008 10:51 PM
05-15-2008 07:37 AM
05-15-2008 10:14 AM
Karem,
Sounds like there are plenty of people willing to help you, but you really haven't given us much information about your system.
If you let us know what hardware (ie camera type - analogue, USB or Firewire and interface if any) and software (labview version, Vision development module version and IMAQ software) you are using we may be able to hlp you further.
A better description of the problem and some example code that you're trying to use would also help.
Dan
05-16-2008 03:53 AM
05-16-2008 04:03 AM
