Machine Vision
Vision Builder not running on Windows 8 Compatible?
I just installed (and re-installed) NI Viowion Builder  (2012 SP1 f2) on my Windows 8 computer.
It starts to come up I tellit to run in evaluation mode and get the next screen
Vision Builder for Windows"
and it freezes , nothing else happens. Task manager says it is not using any CPU cycles, Disk or network, and 161MB of memory.
I am using Windows 8 - 6.2.9200 Build 9200, I7 CPU, 12 GB mem
Any suggestions?
Judd
Judd
(3,955 Views)
It sounds like you are running in evaluation mode? Has your trial period expired?
(3,932 Views)
Use NI License Manager to activate it.
http://www.medicollector.com
(3,899 Views)
please, check Vision Builder 2012 readme file:
http://download.ni.com/support/softlib//vision/Vision%20Builder%20for%20Automated%20Inspection/2012/...
Compatible OS are Microsoft Windows 7/Vista/XP SP3/Server 2003 R2 (32-bit)/Server 2008 R2. Windows 8 is not listed. If You want to use Vision Builder with Windows 8, You should go with versions of Vision Builder 2013 or later which are Windows 8 compatible.
(2,910 Views)
