07-07-2015 03:07 PM
Which kind of problem is this? How to solve it?
07-08-2015 09:41 AM
First suggestion - you have enabled scaling here:
If you have 150%, try to set to 100% first.
07-08-2015 10:06 AM
Ok That worked.
Is there other way to get it work while scaling was still there?
Because fonts and all too tiny for me!
07-08-2015 10:38 AM
Hard to say... Theoretically with 125% you should be fine (with your resolution it should be OK).
Also you can try to disable display scaling here:
but then you may get some "screen effects" in VBAT, such overlapped controls, etc.
07-08-2015 04:36 PM
Ok Thank you very much for help.
