Machine Vision
Vision Builder AI won't start!!!
Which kind of problem is this? How to solve it?
(4,368 Views)
First suggestion - you have enabled scaling here:
If you have 150%, try to set to 100% first.
(4,289 Views)
Ok That worked.
Is there other way to get it work while scaling was still there?
Because fonts and all too tiny for me!
(4,279 Views)
Hard to say... Theoretically with 125% you should be fine (with your resolution it should be OK).
Also you can try to disable display scaling here:
but then you may get some "screen effects" in VBAT, such overlapped controls, etc.
(4,268 Views)
Ok Thank you very much for help.
(4,252 Views)
