06-17-2015 05:05 AM
Is it possible to have different exposure times and frame sizes with a line scan camera, basler racer, in different steps.
I want to trigger in the first step with the next step. In the first the the camera make 37 frames per second. The frame size is 6144 x 256 px.
in the second step I want to do a measurement. The camera should make 1 frame per second. and the size is 6144 x 4726.
Is there any possibility to solve this problem?
06-17-2015 06:49 AM
Which interface are you using : GigE or CameraLink ?
06-17-2015 01:24 PM
06-30-2015 01:43 PM
If you are using VBAI with a GigE camera, I think you might be able to do this with the Read/Write Camera Attributes in the Acquired Images tab.
