08-23-2015 08:11 AM
Hello!
I want to ask a few questions.I am working on diploma project using Vision Assistant.The project is about LCD display recognition of multimeters.I've made the part with the recognition and exported the script to Labview.Now I want to use the recognised data string and use it in table.How can I do that? Can you tell me how to show image taken with the camera in real-time, not only with filters ?
I hope you have understand me and will give me seme guidelines. : - )
Sorry for my English.
P.S
I've attached 2 files so you can understand me better.
08-25-2015 02:16 AM
Hi!
First of all - I need to say your program to recognise numbers made impression on me 🙂 If you can (it's not a commercial project or something like that) please send me (here on in private message) the full code, how you recognise the numbers, I'm really interested in that.
Second thing, I'm not sure what you want to achieve exactly so I found for you some tutorials, that should be helpful:
http://www.ni.com/white-paper/7571/en/
https://www.youtube.com/watch?v=_GlQ1riWjPc
If it's not exaclty what did you expect, please specify some your needs, I will try to help you 😉
Best regards
