09-17-2014 01:15 AM
09-17-2014 05:52 PM
You need to download version 1.3
Use the LabVIEW Import DLL tool
Point it to the VimbaC dll, not C++
Put _WIN32 in the compiler directives. This will get you part of the way there.
09-18-2014 01:05 AM
Thanks for replying!
We where trying to use the .NET assembly but it made Labview crash at the first call...
We'll follow your suggestions and let you know
Marco
09-20-2014 01:38 AM
I've successfully called the Startup() function and listed the available cameras.
Of course I had to fix the auto-generated VIs, but that's part of the fun.
Marco
01-12-2015 08:43 AM
I would like to use vimba with labview
i did say that MoviJohn but i'm stuck
Have you changed the VI and could you share?
thank you,
01-12-2015 10:12 AM
Hi Fred,
I had some problems calling VimbaC directly from Labview when big clusters were involved.
So, at the end, I wrote a C wrapper around the VimbaC dll...
Marco
01-12-2015 07:10 PM
Hi Fred,
I do not have a VI to work with VIMBA. What I provided to Marco in this post was advice on how to import the VIMBA DLL into LabVIEW. From there, you would need to study the VIMBA API. I do not have any other exprience with the VIMBA drivers. Sorry.
03-17-2017 06:35 PM
Hello MacroMauri.
I have recently been tasked to make a allied vision camera work with LabVIEW. i came across your post. i see that you had success creating a vimba wrapper for LV. i am having issues making it work. would you be able to post your wrapper. i would be greatful to you
03-23-2017 01:29 PM
any help MarcoMauri ?
07-12-2018 10:44 AM
Hi
I read that you were able to use the VIMBA SDK .net assembly .
When I try to open the constructor I receive an error that labview is not able to load the assembly.
I'm using labview 2016 64bit and the last vimba version 2.1.3
Please can you help me on this topic?
Thank you
Br, Orlando
