NI Home
Cart Cart | Help
You are here:
Reply
Member
longd99
VDM2011 is included in VAS2011 ?
I install VAS2011 in CVI2010 environment,I found CVI to increase the NI-IMAQ functions and the VDM Vision function,
The full functions of the VDM2011 included in VAS2011? Whether to install VAS2011 do not need to install VDM2011?
I do not need the Vision Assistant of VDM
thanks!
Active Participant
Silver_Shaper
Re: VDM2011 is included in VAS2011 ?
Hi
If am not wrong its exactly reverse as you said VAS2011 included in VDM2011 - out off topic
No, Contains basic functions related to interfacing camera with labview.
No not needed, you can install it separately.
Hope answered your question.
Sasi.
Certified LabVIEW Associate Developer
If you can DREAM it, You can DO it - Walt Disney
Member
longd99
I is to install VAS2011 in labwindows,The full functions of the VDM2011 is include in VAS2011,do not?
I only installed the VAS2011,Have seen a lot of the VDM library function
Seems to be complete.
Active Participant
BlueCheese
I think it is shown because the function palette doesn't reflect current license status like LabVIEW does. If you call functions that require a VDM license you will likely get an error that your license is not activated. The basic image functions should work without a VDM license though. Eric
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
