05-15-2014 10:38 AM
I use the step "Simulate Acquisition" for long time in the configuration interface but not in the inspection interface.
I have created a "file path control" on my inspection interface and I wanted to know how to use this control as the file path for where are my images.
Yoann
05-15-2014 10:43 AM
In Vision Builder AI 2013, we added support for previous measurements in the Simulate Acquisition step so it's easy to select your Custom UI file path as the value to use for the path. There's not a good way to do this in earlier versions of the software though.
Hope this helps,
Brad
05-15-2014 10:48 AM
Thanks you Brad,
It permit me to stay in configuration mode because I'm on the 2010 version so that I can't do easily what I want.
Kind regards
05-15-2014 11:03 AM
You could use a Run LabVIEW step to accomplish the same thing, but it would be more work. If upgrading isn't an option, something to think about at least.
