Machine Vision
VBAI Rotate Image 90 Degrees for Display
So, to calibrate the camera, I capture an uncallibrated image, locate the 2 reference edges, and then use a calibrate step to create the 2-point calibration parameters that I can then use for normal iamge captures to produce real-world dimensional measurements.
Great.  That definitely makes things simpler on the measurement side!
Thanks, Christophe!
     Nelson
Message 11 of 12
(2,208 Views)
Hello Christophe
I have the same problem as Nelson .
I work with a NI 1744 smartcam and Vision Builder AI and i search for a possibilty to rotate the Image only
for display purposes.
I'm verry happy as i found your solution . Unfortunately this VI work's not with my Version of Vision Builder .
Is it possible for you to transfer your VI in a earlier Version of VBAI ?
I work with : VBAI 2012 - Build 20120725192017  on an Windows 7 , 32 bit , intel based PC (german Vision if it is
important)
Thanks in advance
Frank
Message 12 of 12
(1,175 Views)
