Machine Vision
VBAI API fails to load/launch inspection
Hi everyone,
I'm facing a problem today with an application that used to work previously. Don't know what happened on the computer, but now, my application doesn't work anymore.
I have tree different VBAI inspections running on the same PC, they are loaded and started through VBAI API functions from a small LabVIEW VI.
The HMI of VBAI appears but never turns into inspecting mode. See screenshot below. The iteration counter stay at 0.
I already checked that the inspection is fully functionnal if I run it from normal VBAI interface.
Could you please help me to troubleshout this issue.
Many thanks for your answers.
(3,888 Views)
Accepted by topic author toto69
Find the problem by myself!
For an unknown reason, the Vision Builder.ini file was overwritten with default values.
And the line allowmultipleinstances = True was no longer there, preventing my application to load 3 different instances.
By adding this line again, everything went back to normal.
(3,881 Views)
