09-23-2015 02:28 AM
Hi everyone,
I'm facing a problem today with an application that used to work previously. Don't know what happened on the computer, but now, my application doesn't work anymore.
I have tree different VBAI inspections running on the same PC, they are loaded and started through VBAI API functions from a small LabVIEW VI.
The HMI of VBAI appears but never turns into inspecting mode. See screenshot below. The iteration counter stay at 0.
I already checked that the inspection is fully functionnal if I run it from normal VBAI interface.
Could you please help me to troubleshout this issue.
Many thanks for your answers.
09-23-2015 03:49 AM
Find the problem by myself!
For an unknown reason, the Vision Builder.ini file was overwritten with default values.
And the line allowmultipleinstances = True was no longer there, preventing my application to load 3 different instances.
By adding this line again, everything went back to normal.
