02-25-2010 02:57 PM
Adrian,
You can confirm it is not an issue with IMAQdx by verifying that the Point Grey camera does not appear in other DirectShow applications such as Microsoft NetMeeting, other video conference apps, or utilities that Microsoft provides such as AMCAP.
As for figuring out what is wrong with the Point Grey driver install, I'm afraid I am unable to help you. I've struggled with their installers in the past with regards to upgrades from existing versions and I've run into similar-sounding issues. Luckily I have the luxury of simply re-imaging a test machine to a pristine state.
Eric
07-28-2010 05:44 AM
Hi Il Papu,
I have the same problem with the same Point Grey camera (Chameleon)
Did you find out how to solve this problem or not?
Marius
07-29-2010 07:17 PM
Marius,
I was able to partially fix the problem. I got the camera to work once I purchased Vision 2009. This solution only worked for a 32 bit system. My Windows 7 64 bit system still does not recognized the Point Grey camera.
09-29-2010 02:36 PM
I had a similar problem with the Point Grey Chameleon. I had the latest version of FlyCap Software (the PtGrey drivers) and what I had to do was follow the instructions on the Point Grey Knowledge Base article 310. Here it is copied.
CAUSE:
Sometimes when installing or upgrading the FlyCapture SDK, the DLL files that enable the camera driver to work with DirectShow interfaces are not registered to the Windows Registry. As a result, DirectShow applications do not work with the camera. When this happens, you must register the DLLs manually.
ANSWER:
To register DirectShow DLLs manually:
Note: If this procedure results in error 0x80004005, run the Command Prompt utility under elevated privileges. To do this, right click on the Command Prompt shortcut icon and select Run as…Administrator.
09-29-2010 03:58 PM
So are you saying you got it to work in a Win 7 64-bit environment?
01-25-2012 06:52 PM
The way to make it work for Win7:
1) install Flycapture2.2.3.14 x64
2) install Flycapture2.2.3.14 x86
I was able to make it run after installing these drivers in that exactly sequence (maybe reversed one will work as well).
Flycapture 1.x doesn't seem to work for Win7 period. At least i wasn't been able to run it at all after trying everything there was to try. Installing just Flycapture2.2.3.14 x64 also doesn't work by itself.
www.xinstruments.com - Custom Software for Industrial Automation
www.hdrconverter.com - Picture processing made easy
