04-19-2012 01:33 AM
Hi Eric,
Thank you for your reply! That's actually exactly the settings I am using...
But how can I send a software trigger to the camera?
Ben
04-20-2012 12:48 PM
Hi Ben,
A software trigger is used at the software level and it is not used to send an actual signal to the camera. You are telling the software to start acquiring when triggered. Where are you currently at with your program? Are you able to acquire images after pressing an execute button? Are you getting any errors? Make sure your VI recognizes your button is being press and that it is not just called once on start up. Try wiring up a true value to where you button is and see if that works.
Tim O
04-20-2012 01:50 PM
@Tim O wrote:
Hi Ben,
Tim O
That's not true. The "Trigger Software" feature is a camera feature that allows it to expose a "virtual" trigger signal that can be signalled via software in a generally low-latency way. To software it looks pretty much the same as a hardware trigger except you are generating a command to the camera to cause it.
To send this command, the attribute on the camera is "TriggerSoftware". It is implemented in GenICam as a "Command" feature, which means it looks somewhat like a self-clearing boolean feature that you push and then it clears automatically. In IMAQdx you can trigger it by just setting that feature to "true" in your code (it will self-clear). So you could do this in LabVIEW by setting the "ActiveAttribute" to "TriggerSoftware" and then the ValueBool property to "true".
Eric
08-08-2015 05:52 PM
Hi Eric and everyone,
It seems this topic is still insisting to show up.
I did my best, studied the Basler manual and saw the example. Attached is the best I have reached, i thin I'm close to exposing on SW trigger.
My issue is, no matter what I do, acquisition runs continuously, as if trgger mode is set to off. However, when I remove the 'TriggerSoftware' command set from the while loop, the loop terminates on timeout (which is obvious).
Can someone tell me what's wrong with my setup ?
Thanks in advance 🙂
08-10-2015 11:51 AM
Hi omarbedair,
I wanted to let you know your questions will gain more visibility by creating a new thread (of course you’re welcome to mention this thread to provide background). This thread has been inactive for multiple years and is unlikely to get many views; also, we recommend not posting extremely old threads.
Below I’ve attached a link with helpful resources for using the NI Discussion Forums.
http://forums.ni.com/t5/Getting-Started-on-the-NI/bd-p/gettingstarted
I hope you find these helpful!
Kale
08-10-2015 01:07 PM
