09-16-2002 05:54 AM
09-16-2002 11:20 AM
09-21-2009 10:54 PM
Hi Bruce...
How are you today...?
I'm working late today, I have to finish a code for friday morning, is my time line,
I want to do a vision inspection in a display, I just found this code, i downloaded did not work
some vi are missing, "vi is not executable" I',m pretty sure is a software version I'm running
LabVIEW 7.1 NI Vision 7.1 and VAS 8.5. I know this is for 7 segments display, I will need to
do something in another project that I'm quoting..
Attatch you will find and image of the display. I ran OCR, seem to work OK for me but I have
a little trouble with the letter "M".. OCR separtes in 2 or 3 characters, I think I can manupulate the
string 3 charactes = to "M".
Thanks for you help...
09-22-2009 09:55 AM
Doing pretty well, thank you.
It looks like OCR should work fine on this display. Here are a few observations:
The space between the two parts of the M are about the same as the space between the F and the M. If the M space was smaller, I would recommend adjusting the spacing parameter that adjusts max space between components of the same character. That still might help you out to join the character pieces.
Each section uses a different font, so it might be useful to define a separate font for each section, if your analysis can read each section separately. If you have to read the entire line at once, you will just need to merge all the fonts. There is more possibility of error when you mix fonts.
Bruce
09-22-2009 12:27 PM
Hi Bruce..
Thanks for you quick response.
I will consider your comments on my code..
I'll keep in touch.. Take care...
Best Regards...
