10-29-2014 10:17 AM
Thank you K.
BTW, have you caught the depth value(z axis) from these two code? My main purpose is tried to get the value in axis of X, Y and Z.
B.R
Ivan Cheng
10-30-2014 02:13 AM
yes, the point of stereo imaging is to obtain the depth/distance value of the measured feature/object. One of the codes uses a block matching algorithm (Labview native) for the entire image and the other is based on feature detection (point-to-point matching and depth extraction).
K
10-30-2014 02:56 AM - edited 10-30-2014 03:00 AM
Hello K,
Could you help me check whether the attached calibration file is ok to generate "Stereo Calibration Data.calib" as I tried several times and changed the path again and again, but still cannot working properly.
Thank you for help.
B.R
Ivan Cheng
10-30-2014 04:54 AM
@Ivan0907 wrote:
Hello K,
Thank you for help.
B.R
Ivan Cheng
Attachment?
10-30-2014 09:56 AM - edited 10-30-2014 09:56 AM
Hello K,
Please see the attachment, thank you for help.
B.R
Ivan
10-30-2014 03:05 PM
this seems to be the same attachment (calibration) I've posted? The code works ok, I have successfully calibrated my system.
Still, I don't know what is your problem. If you use the code, the program asks you at some point to save the calibration data. If you confirm this, the calibration data is saved in the same folder where the left and the right calibration grid images are.
K
11-03-2014 03:47 AM
Hello K,
Thank you for confirming.
I have tried the software under Win 8 and Win XP, but there isn't any calibration data can be generated, i'm not sure what wrong with here.
Do you have any idea for me for this? Or is there any information I could send to you for checking of this again?
B.R
Ivan
12-04-2014 01:27 AM
Hi K,
I try several time, but still cannot catch the calibration data in that indication folder.
Could you help to use the screen2.exe (a free software for you record any video in computer) to record all your operation procedure in calibration? I'd like to know if any different wtih me.
Also in the code, I got confusion in a component which is "Learn stereo calibration" in the page1, can you explain what is this and relative funcion for this? I think it was made by yourself.
Thank you.
B.R
Ivan
12-10-2014 05:58 AM
please see the relevant steps in the attached image files.
1. After selecting the correct (already) acquired images path and the grid spacing (settings tab), run the program.
2. On the pop-up, select the top-left grid point in both images (these establish a calibration axis origin). Select OK.
3. On the pop-up, confirm to save the calibration data.
4. Find the calibration data in the parent folder of the images you've used for calibration.
Hope this helps.
K
12-10-2014 09:53 AM
Hi K,
Thank you for help.
Can I know how many left image/right image have been used in your calibration? And to acquire these images whether need to have any movement for each image?
B.R
Ivan
