12-04-2013 08:08 AM
Does the NI 1429 FrameGrabber work together with Sony XCL C30c ?
Unfortunately there is no preconfiguration file for the camera and in the CameraLink File Generator
we get no response from the camera using for example serial communication.
We do not get any sign of life from the camera. We have plenty of them so we assume not all are defect.
Also the cameras are capable of PoCL but in combination with the NI1429 we use a working external
power supply.
Thanks in advance.
PS: The FrameGrabber works since we can connect to a Basler 504k.
12-09-2013 10:44 AM
Hi cgv,
the Camera File Generator takes your cameras specifications and
translates them into a file-format which the NI-IMAQ driver understands.
Did you type in all the specification data?
A good starting point might be the definition for a camera of the same brand and series.
The SONY XCL-5000.icd could be the right one as this is the latest file from the XCL-series.
If this file doesn't work please carefully observe the differences between the cameras and
change the settings accordingly.
What Framegrabber Specifications Do I Need to Know When Using the NI Camera File Generator?
http://digital.ni.com/public.nsf/allkb/E16D3364AD5D8C1C862576160075AF93
Peter
