Running LV2010, I have a master calibration image saved as a .png. (It's big - 83MB). I snap an image then use the master to correct my acquired image. (Both are the same size.)
Most of the time this works exactly as it should. Sometimes the Set calibration Info vi throws an error (code -1074396113) and says the image was not calibrated. Once it's done this the error occurs every time the vi runs. The only way to fix it is to get out of Labview completely, then open it up again.
Any ideas why it is behaving this way? More importantly, any ideas how to stop it behaving this way?
