05-11-2016 11:52 AM
Hi everyone,
For the purpose of using pattern matching, I am first trying to select the area I want to explore. I use a camera from which I take photo and I want to analyze it later. I want to select the whole picture to find patterns (like circles or rectangles). My problem is that I need this to be automatic and I am not understanding how to configure the ROI. I tried to create a ROI descriptor but I don't understand how to send the data as a whole.
I have the feeling this is not very hard, but I think I am stuck in some thoughts. Can someone give me some tip to understand how to work with this?
Thank you!
Solved! Go to Solution.
05-11-2016 05:40 PM
use this vi to lrean how to make ROI
use dirffernt RIO to find relate numbers and type of array points
05-12-2016 08:39 AM
Thank you for the answer!
Unfortunatelly I can't use the file, as I am using the version 2012. Is there any chance to get a later version of that VI?
Thank you!
05-12-2016 10:02 AM
use this
05-12-2016 10:57 AM
Thank you!
I managed to create a ROI in the program after reading that VI 🙂
