06-02-2015 07:11 AM - edited 06-02-2015 07:14 AM
I have a quite noisy screen image with all screen pixels on. I need to detect all pixels from the screen but i have problems to find them all. So, my question is if it is possible to detect all 8192 pixels from the picture? I know it is possible to do in parts where I draw ROIs separately to objects which are not found by Detect Objects step but this is not very professional. Is there any way to process image to ease the detection? I tried couple of methods but none worked perfectly. See attachments.
Br,
Jick
06-02-2015 09:28 AM
The first thing I would do is calibrate the image to remove any distortion. After that, if you know the coordinates of all four corners you can easily step through all the points using a grid approach. You could do centers or edges, doesn't really matter.
Of course, this would all need to be done in LabVIEW.
Bruce
