11-13-2015 11:49 AM
Hi
I have attached the vi I have for recording a section of video from a grab of a USB camera. However, once I get the avi file it has broken links and won't play. I am also trying to manually set the frames per second with the input I have but I'm not sure where I went wrong as the readout is not correct.
I've attached the vi I'm using.
Thanks for any input.
Solved! Go to Solution.
11-16-2015 11:11 AM
Hello goldfronts,
What do you mean by broken links?
Have you tried the Grab and Save to AVI example?
If you want to change the frame rate of the camera and the AVI file, you can use the instructions in the following link:
http://digital.ni.com/public.nsf/allkb/ED1100E971E6685F86257CEC005F4D23
11-16-2015 11:37 AM
11-16-2015 11:40 AM
11-17-2015 08:58 AM
Hello goldfronts,
It appears as though you are creating two AVI files. Do both AVI files break?
If you use the example, does the output AVI file break? This step will help point us towards the root cause.
11-19-2015 08:43 AM
Yes you are correct I was creating two avi's. Thanks for the help.
