08-25-2015 03:06 AM
Hi
I am saving images as PNG with a overlay. Overlays are only text. I need to batch process images to change the overlay - is the a way to read the text from a overlay on a saved PNG or get to the individual elements of the overlay so that I can change them and resave?
Nic
08-25-2015 04:55 AM
Hmmm.. I'm not sure if there is access to the Vision Info, even if I'd like to have it..
The image processing person in me would copy the overlays to a white image, merge them and do OCR, but that is my personal approach 🙂
If you have any control over the saving process, use custom keys instead of overlays to store your data.
Birgit
08-25-2015 05:00 AM
Hi
At the moment the overlays are saved by someone else's software and I can't change that.
Custom keys??? Can you explain.
Nic
08-25-2015 05:46 AM
Custom keys are a way to store the data into the header of the image file without being visible.
I will attach a screenshot from yet to be published material on how to use them 🙂
08-26-2015 08:12 AM
Nice post, b.ploetzeneder!
I second b.ploetzenender's idea. I would recommend trying OCR to find what letters are overlayed, find their position and then masking them. Or if the letters are a certain color, then trying a color threshold to isolate them, and then mask, and add the overlay that you want. Do you have any sample image that you could post?
