03-03-2015 12:37 PM
HI,
I am currently in the process of developing a vision system that uses a USB3.0 Camera module with an Aptina CMOS sensor - the image output is RAW but is wrapped in a YUY2 format to make it UVC compliant. So when I use Labview to capture an image I get a greenish image and the output format is recognized as YUY2 and no other options are available. The camera uses Directshow drivers for the capture. I have been struggling to convert this RAW image to a useable RGB32 format image that I can save and do some post processing on.
I have the vendor's souce code and invoke a C++ DLL but it crashes Labview while trying to run the raw to bmp subroutine - I have narrowed it down to an input/output mismatch - the input is a pointer to the image buffer and uses the BYTE (unsigned char) data type. The expected output is a 3D array with 4 x 2592 x 1944 for the 4 color planes R, G, B, Alpha 8 bits each for the RGB32. I have tried pretty much all possible combinations of image handle, array data pointer, C++ string pointer and array options as input for the buffer but unable to get the DLL to work. Any inputs are appreciated here.
Has anyone else encountered this Greenish image when capturing a RAW image and displaying it? Any ideas of how I could do the conversion in Labview?
Some more details of the image - used the Get ImagePxl Pointer to find out more details
2592 x 1944 pixels
Line width : 2608
Border size - 3 pixels
Pixel size 4 bytes
Transfer max size : 20279808 bytes
So the image buffer is a 4 bytes per pixel
Thanks.
03-03-2015 02:37 PM
You should be able to do this without a DLL. I'd suggest using IMAQdx's "Get Image Data" to get the raw image buffer without any conversion as a 1D array of U8. Re-shape it to an 2D array of the sensor size. Then call "IMAQ Bayer To RGB" to do the de-bayering.
Eric
03-04-2015 10:01 AM
hi,
could you post a sample image?
Alex
03-04-2015 09:19 PM
Hi Eric, thanks for the suggestion - I had tried that before and i tried it again. Gives me a blue pic if I convert it into a 2D array of the dimensions and change array to Image. Also the Bayer to RGB gives the same image.
The image data is supposed to be RAW 16 bits from the camera but somehow LABVIEW is giving me a 1D array of 4 bytes per pixel instead of two bytes as if it reads that as a YUY2 format and makes it a RGB32 image .
Hi Alex, I have a attachment of the type of image in my first message itself.
Ashwin.
03-04-2015 10:22 PM
03-05-2015 12:08 PM
Thanks Eric, that's probably what I was thinking initially that I wasn't having any options to change drivers. Now is there any way I can add a Bayer filter that I have added to my Directshow filters and pass the data through the capture pin before i get it into Labview?
I am stuck with this camera for the form factor. it is a 26 x 26mm camera and not many are around for the application that I am trying to build it for. Any possibility of invoking a C executable inside Labview that will do the capture image and save as bmp outside of Labview? I am relatively new to Labview but have lot of programming experience in Fortran/C++. My choice of Labview is to enable a lot of post image processing in the lines of pattern recognition, differential maps, measurement checks etc.
Ashwin.
03-05-2015 12:13 PM
Basler has the acA2500-14uc with the same resolution and 29mm x 29mm for $500 USD. Does the three extra mm make a difference? Their cameras work great.
Bruce
03-05-2015 12:14 PM
Sorry, I don't know of an easy way to inject your own filters in that path. The DirectShow graph if pretty much rendered automatically from IMAQdx's perspective.
Are you sure you can't find a replacement camera? Basler has a Dart model with that same sensor that is pretty close in size:
http://www.baslerweb.com/media/documents/BAS1501_dart_Broschuere_EN_SAP5052_web.pdf
There's also Ace models of similar size...
Eric
03-05-2015 12:16 PM
Thanks Bruce, But my max size can only be a 27mm x 27mm max and I already have the hardware ready to go. The camera works great on the manufacturer's software. Hope I can make something work.
03-05-2015 10:11 PM
