09-11-2014 08:35 AM
I have a WIN7 64-bit system with a new NI-8242 USB 3 card. I also have a Point grey USB 3 Vision camera (GS3-U3-23S6M-C) which works fine with the Point Grey FlyCap software and NI USB card.
The camera is not detected in Automation Explorer and there is no NI-IMAQdx entry in the tree. The camera (and NI) instructions say to change the camera driver to one found in C:\Program Files\National Instruments\NI-IMAQdx\Staging\NI USB3 Vision, but my driver is located in C:\Program Files (x86)\National Instruments\NI-IMAQdx\Staging\NI USB3 Vision.
Attempts to install the driver pop up the following message:
"The folder you specified doesn't contain a compatible software driver for your device. If the folder contains a driver, make sure it is designed to work with Windows for x64-based systems."
This makes it sound like the driver is in the wrong place or it is not made for a 64-bit OS. Any advice is appreciated.
09-11-2014 08:49 AM
09-11-2014 09:05 AM
This camera showed up only a few days ago so I assume it is up to date. The camera description also indicates USB Vision compliance.
Of course I should check for a firmware update anyway...
Thanks.
09-11-2014 09:20 AM
The camera firmware was old (v1.5...) and needed to be updated (v2.7...). This was successful and I can now see the camera in Automation Explorer. Thanks!
01-20-2015 02:16 AM - edited 01-20-2015 02:23 AM
I am having exactly the same problem described by cvstan with Sentech STC-MBA5MUSB3 USB3 camera. It doesn't look like it is possible to update firmware in this case. Any suggestions will be greatly appreciated. Environment Win 7 Pro 64bit with LV 2014 32bit. Sentech 64bit driver.
01-20-2015 03:18 PM
Hi aderogba,
The USB3 camera you are using does not seem to comply with the USB3 Vision standard. Not all USB3 cameras follow this standard even though they may support use of the USB3 bus. Cameras that comply with this standard usually have it written somewhere in their manual, but I was not able to find any mention of it in this manual:
http://videor.com/imaging/media/assets/filelink/204787_de_sup.pdf
To see cameras that are supported by NI, here is a rough guideline of the different standards:
http://digital.ni.com/public.nsf/allkb/4331B4AA3AE95233862574C200539A2F
If you have any further questions, I would recommend creating a new post as that will get more views and more people would be able to help you. Putting it as a comment in a 4 month old thread will not have as many views as a new post.
07-02-2019 08:37 AM
I am having the same issue with the same camera for our lab setup. Do you know how you update the firmware on this camera? Mine also doesn't show up in the NI MAX tree but does appear in flycap2. Do you have any suggestion on what you did or how to update the firmware?
