NI Home
Cart Cart | Help
You are here:
Reply
Al-Zahrani
Object Tracking Project
Hello, Everyone
I saw in youtube this project " Object Tracking using Image processing "
http://www.youtube.com/watch?v=M8-q8ASNAes&feature=related
and  I try to do the same by my Laptop camera (640x480 YUV2 30fps)
I attach the VI , but I face the error in the picture
could you help me to solve that error?
front b
error
best regard
Alzhrani
JtotheB
Re: Object Tracking Project
The image that you have wired into the template input is not a template. You have to wire this output to the template input on your match pattern VI;
John B.
Embedded Networks R&D
Certified LabVIEW Developer
Al-Zahrani
Hello John
Thank you for reply, I try to do that but I  have error.
could you correct that VI
and attach it ?
Best Regard
Alzhrani
JtotheB
Attached.
John B.
Al-Zahrani
Hello, John
Thank you for attached VI, but it dos'nt open with me because I have LabVIEW 2009
could you please save it as 2009 Version
Best Regard
Alzhrani
JtotheB
Sorry about that, I attached a down converted version.
John B.
The Caribbean
[ Edited ]
Hi John,
I need to make tracking for an object too. I try to use the VI post by you but it does not work.
best Regards,
The Caribbean
Hornless.Rhino
What error do you get?
The Caribbean
After I select the ROI, I push "searching" and the VI do nothing! No tracking the object selected.
ajita24patil@gmail.com
Hello i am also doing project in object tracking and i have done a small vi related to online video.
I m new to the labview software. I am using acqusition and assistant but not getting proper results.
I am attaching pic of block diagram of the try i have done.
Please help me for this problem.
I m hoping for positive reply.
