09-07-2011 07:25 PM
Hello, Everyone
I saw in youtube this project " Object Tracking using Image processing "
http://www.youtube.com/watch?v=M8-q8ASNAes&feature=related
and I try to do the same by my Laptop camera (640x480 YUV2 30fps)
I attach the VI , but I face the error in the picture
could you help me to solve that error?
best regard
Alzhrani
09-08-2011 12:54 PM
The image that you have wired into the template input is not a template. You have to wire this output to the template input on your match pattern VI;
09-12-2011 03:22 AM
Hello John
Thank you for reply, I try to do that but I have error.
could you correct that VI
and attach it ?
Best Regard
Alzhrani
09-13-2011 01:58 PM
Attached.
09-14-2011 05:03 PM
Hello, John
Thank you for attached VI, but it dos'nt open with me because I have LabVIEW 2009
could you please save it as 2009 Version
Best Regard
Alzhrani
09-15-2011 03:55 PM
Sorry about that, I attached a down converted version.
05-05-2012 07:47 AM - edited 05-05-2012 07:47 AM
Hi John,
I need to make tracking for an object too. I try to use the VI post by you but it does not work.
best Regards,
The Caribbean
05-06-2012 08:28 PM
What error do you get?
05-07-2012 09:00 AM
After I select the ROI, I push "searching" and the VI do nothing! No tracking the object selected.
05-07-2012 09:38 AM
Hello i am also doing project in object tracking and i have done a small vi related to online video.
I m new to the labview software. I am using acqusition and assistant but not getting proper results.
I am attaching pic of block diagram of the try i have done.
Please help me for this problem.
I m hoping for positive reply.
