03-20-2014 11:04 AM
Hi sprayer,
sorry for the late response, I will try it tomorrow and I will give u the feed back for sure! and thank you very much for your time!
Shiva
03-20-2014 12:45 PM
Shiva,
I had asked you if you have access to LabView or other programming language. One problem you may experience is that the Staubli will timeout waiting for an input string and crash your program. I don't think HTerm has the ability to send a keep alive string, it only sends what you type when you hit ENTER. We use a custom LabView program so if the user stops typing for more than 1 second, LabView starts sending 'Keep Alive" to the Staubli so the connection is not dropped. The alternative is to drastically increase the Staubli timeout from 5 sec to maybe 300 sec (5 minutes) depending on how fast or often you are sending text.
03-20-2014 12:52 PM
sprayer,
very useful information, but i dont have any access to lab view
Shiva
03-21-2014 05:35 AM
Hi Sprayer,
1. Yes, we need a gender changer for connection
2. I have opened my H-Term, I couldn't found Properties>>Settings>>ASCII Setup in file (I am using HTerm 0.8.1beta). I couldn't found 'Send Line Ends With Line Feeds' option as well
3.In HTerm connection I have choosen Com12, and I couldn't found TCP/IP (Winsock). Where i need to check the TCP/IP (winsock) option in H Term or else in Stäubli software?
Thank you.
Shiva
03-21-2014 10:59 AM
Shiva,
Well, I am confused. We run WinXP which has HTerm 5.0. I could not find a reference to anything older than Win2000 had HTerm 4.0 - and that is already 14 years old. What operating system are you using? I think your work would be greatly benefitted by connecting a Win2000/XP/7/8 computer to the Staubli. I am not sure I can solve the communication problem if you are using HTerm 0.8. I do not have access to HTerm 0.8 or anywhere to download it from.
-Sprayer
03-21-2014 11:41 AM
Sprayer,
I am using windows 7 professional. So, should I try downloading a old version of Hterm?
-Shiva
03-21-2014 11:57 AM
Sorry, now I am more confused. In your earlier post you indicated that you had HTerm 0.8. Did Win7Pro come with HTerm already installed, or did you have to install it? Since you have Win7Pro HTerm should be detecting your ethernet card. The Hilgraeve website says v7.0 is the newest for Win7/8. I am still not sure where you got HTerm v0.8 from. Please try to download version 5, 6.3, 7. Maybe post/upload a screen shot of your HTerm about window. Thanks.
We will get this sorted out. 🙂
03-21-2014 12:25 PM
Sprayer,
Sure i will send you a screen shot on monday and I will let you know exactly my Operating system as well.
I have to instal it seperatly! could you please send me link where to download these versions, I have tried but couldn't found these versions.
Thanks for your support
-shiva
03-24-2014 04:44 AM
Hello Sprayer,
I am using microsoft windows xp professional version 2002 service pack 3. I am attaching HTerm screenshot as well, please have a look.
Thank you.
Shiva.
03-24-2014 04:48 AM
sorry forgot to say that, I am not able to find any other versions of HTerm. could you please send some links of other versions?
Thank you.
Shiva.
