Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
10-07-2015 03:45 PM
I'm looking for dedicated IR blocking filters for the NI 1752 Smart camera. I had no luck finding any online.
The filter needs to block heat radiation emitted from steel at 1100F.
Any input is appreciated.
-Hazim
Solved! Go to Solution.
10-08-2015 07:02 PM
The 1752 uses a C-mount lens, so you should be able to add a lens filter that is compatible with a C-mount.
Thanks!
We'll be in touch soon!
