06-23-2014 11:20 AM
I have basler aca2040 180km camera and NI PCI3-1433 card. Both work well most of the time, but occassionally, the camera would stop acquiring data. I checked the camera in the MAX; the camera initially was able to acquiring data, and then after a few seconds it errored out, with a time-out error.
The interesting part is if I unplug and plug the cable, the camera started working again. It worked every time. But after a while, you have to repeat this again.
Is this a cable issue? Should I order new cables to see if it matters? Does anybody else see this before?
06-24-2014 05:01 PM
Hi MengHuiHanTang,
How long does your camera work before you start running into this issue? Is there any corolation to this problem or does it seem fairly random?
06-25-2014 03:01 AM
The first thing i would do is replace the cable and check whether the problem persists. Did you change any timeout setting in max?
06-25-2014 09:31 AM
This issue does not happen often, and it seems to be random. I used to think it was related to dust maybe.
I might start from replacing the cables first to see if it matters. If it does not happen to the new cables for, say, 6 months, I would be sure that it was a cable issue.
06-25-2014 12:20 PM
Also is there a chance that the camera might have got physically damaged?
06-25-2014 12:30 PM
I don't think so. This issue has shown up repeatedly, but the camera is still acquiring images fine.
