04-22-2015 12:42 PM
Bonjour,
Je souhaite avoir des idée pour réalisder un systeme de contrôle d'un mire de coleur vert pour un afficheur LCD.
Comment vérifier si toute la surface est en couleur vert ?
Comment vérifier si la couleur est uniforme pour toute la surface ?
Exemple en piece jointe
Merci d'avance
04-23-2015 10:00 AM
Hey Tanite!
3 Tips you can follow to get started:
1. You can start by studying and then modifying the LabVIEW examples from the Vision Development Module, specifically the one for color matching, which you can find at:
C:\Program Files (x86)\National Instruments\LabVIEW <version you are using>\examples\Vision\Color\Color Matching.vi
2. Go to LabVIEW » Functions pallete » Vision and Motion » Image processing, and check the functions available (these could help you uild something like what you are looking for too) (i.e Color processing or Processing subpalletes)
3. Go to LabVIEW » help » find examples » Toolkits and Modules » Vision , you can look into the Color, Image processing, texture, and other subfolders and look for an example that fits your needs. Then try to merge or modify these examples once you have understood what each function does.
Best regards!
>>Daniel C.
