08-05-2012 06:21 AM
Iwas trying to upload .vi made by Vision Assistant (Create LabView vi). Everything went well, but after adding Smart Camera NI 1774 as target and opening the Vi I had problems with uploading. Attached screen popped up.
I don`t know what library or part of soft I have to install or where to copy such a library. In another attch there is a screen of already installed soft.
Help me please ![]()
08-08-2012 09:14 AM
Hi mcholewi!
I was able to reproduce the error.
So I created a LabVIEW code from Vision Assistant as you, inserted it to a project.
My target is an NI1772 (mostly the same as 1774) with the softwares attached in a picture.
I got the following error message:
08-09-2012 03:07 AM
Thank you very much for the response. Unfortunately, I am on vacation and it is not possible for me to try out Your solution. I will do it in the end of August.
Best regards
Mateusz
08-10-2012 10:02 AM - edited 08-10-2012 10:05 AM
Hi!
After research I foun out that the solution is included into the error message:
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
