05-03-2016 01:03 PM
Hello: I have 2 new Manta 235C cameras installed on a Ni PCIe-8233 Adapter. Both found and function as expected under Allied Vision Vimba Viewer. When I run NI Max, camera 1 functions great, but the other gives a timeout error 0xbff6901b. Windows firewall is off. Any suggestions?
Solved! Go to Solution.
05-04-2016 03:04 AM
Have you set them in different IP ranges?
Epictetus
05-04-2016 07:23 AM
Hello:
I have the IP addresses set up as follows:
Camera 0: 169.254.100.2, 255.255.255.0; Adapter 0: 169.254.100.1
Camera 1: 169.254.200.2, 255.255.255.0; Adapter 1: 169.254.200.1
Both cameras show up in MAX with the above IP's
05-04-2016 07:33 AM
you also can chech that both ports are configured to use NI GigE Vision driver, this is in Windows network settings, you have to select the driver manually :
see also : http://www.ni.com/product-documentation/5846/en/#toc3
Epictetus
05-04-2016 09:44 AM
Hello again:
Went thru all the steps in the document and nothing solved the problem.
I went into MAx to see what, if any differences were in the settings between the 2 cameras. The second camera, the one giving the timeout error was set up under acquisition and the acquisition mode was set to MultiFrame. I set this back to Continuous and now everything works fine.
Thanks for all your help
05-04-2016 05:26 PM
