Machine Vision
Machine Vision 'Vision Acquisition' connect error
when I open "Vision Acquisition" ,this error comes out
and I could't connect my webcam
(2,808 Views)
Can you try opening with NI MAX?
uday
(2,758 Views)
How to open with NI MAX ?
Can you snap a picture please~ Thank you
(2,728 Views)
Accepted by topic author casper7899
-What is MAX:http://digital.ni.com/public.nsf/allkb/71544521BDE34FFB86256FCF005F4FB6
-It should be automatically installed in your PC, try searching for NI MAX in after clicking Windows button.
-Under Devices and Interfaces your camera should be listed and click on that.
-Then use Grab/snap functions and check if you receive same error.
-Check the Acquisition attributes tab, especially Output image Type and Pixel format parameters try changing to defaults and see if you still receive an error: Post Screenshot of NI MAX settings.
uday
(2,720 Views)
It can active right now .
thanks a lot~
(2,671 Views)
